Plugged in while being fully charged.
Discussion in 'Microsoft Surface Help' started by os1019, Nov 25, 2014.
  1. os1019
    os1019 New Member
    Mar 7, 2013
    6
    3
    Is it okay to keep the Surface Pro 3 plugged up after it had fully charged or am I over charging it? This was not issue at first for when the SP3 was fully charged I would unplug it and go about my business. However, now I have a docking station with external HD etc plugged into it so I must keep the docking station plugged in which in turn is charging the SP3.
  2. grumpy
    grumpy Active Member
    Dec 12, 2013
    252
    45
    28
    The SP3 automatically terminates charging once the battery is fully charged, so leaving it plugged in will not overcharge it.
  3. kundas1
    kundas1 Super Moderator Staff Member
    Dec 4, 2013
    1,663
    300
    83
    keeping the SP3 plugged in will not hurt the battery, but it IS recommended that you let the SP3 drain down to 10% once a month to keep the Battery optimal ;)
    os1019 likes this.
  4. daniielrp
    daniielrp Active Member
    Oct 26, 2013
    693
    133
    43
    Preston, UK
    Is this right? I can't help but wonder whether if you keep it plugged in all the time it would then get stuck in a loop of:
    - Charge to 100%
    - Stop charge.
    - Battery drops to 99%.
    - Charge to 100%.
    - Stop charge.
    - Start charge.
    Etc.
    Which doesn't sound like a good idea for a battery. I may be wrong, I don't really know how these work.
  5. jnjroach
    Nov 9, 2012
    7,786
    1,841
    113
    Seattle, WA USA
    Surface Book
    Microsoft own guidance is to at least run it down below 10% once a month....
    Battery care
    • Operating temperature. Surface is designed to work between 32°F and 95°F (or 0°C to 35°C). Lithium-ion batteries are sensitive to high temperatures, so keep your Surface out of the sun and don’t leave it in a hot car.
    • Recharge anytime. The battery doesn’t need to be empty or low before you recharge. You can recharge the battery whenever you’d like. However, it’s best to let the battery run to below 10 percent at least once per month before you recharge it.
    • Battery warranty. If your Surface battery is found to be defective during the warranty period, it is covered under the standard Surface Warranty. For more details about the Surface Warranty or for extended warranty coverage, see Surface standard warranty and Microsoft Complete for Surface.
    http://www.microsoft.com/surface/en-us/support/hardware-and-drivers/battery-and-power-pro
    VickiFL and os1019 like this.
  6. kundas1
    Dec 4, 2013
    1,663
    300
    83
    isn't that what I said already? lol ;)
  7. os1019
    os1019 New Member
    Mar 7, 2013
    6
    3
    Thanks for the info everyone.
  8. jnjroach
    Nov 9, 2012
    7,786
    1,841
    113
    Seattle, WA USA
    Surface Book
    Just reinforcing what you already said :)
  9. grumpy
    Dec 12, 2013
    252
    45
    28
    To help preserve the battery, many devices don't initiate charging until the battery has been discharged at least a few percent. My SP2 won't start charging until below 97% (the SP3 is likely the same) and my Dell has customizable charge profiles.
  10. JackieInCo
    JackieInCo Member
    Nov 23, 2014
    38
    3
    8
    I would use it more than once a month. I would try and use it a few times a week at the minimum on battery.
    I ruined every laptop battery I have had in the past from MacBooks and MacBook Pros to HP laptops because I rarelky had a use to use them on battery power. I did try and use the last MacBook Pro on battery power at least once a week and after a year, it would shut off at 50% and running it down till then several times would not fix it or calibrate it.
    I bough the SP3 because it's different and very easy to carry around the house. I don't travel and have no excuse to really take it anywhere so it will always stay home.
    Microsofts guidelines listed above are assuming that you use the computer on battery power frequently and don't leave it plugged in constantly.
  11. RogerB
    RogerB New Member
    Aug 24, 2015
    19
    0
    Edinburgh. Scotland
    I have my SP3 in the docking station most of the time.
    A) Is it safe to leave the SP3 in the docking station and switched on overnight or even for several days?
    B) Should I disconnect from the docking station periodically to allow the battery to run down?
does it hurt to keep your surface plugged in
if you keep the surface pro 4 plugged in does it kill the battery
leaving surface pro 3 while on vacation
over charging sp3
surface 3 charging cable plugged in all the time
surface battery life keep it on the charging station all the time
surface pro 3 can i leave it plugged in
surface pro 3 is it ok to leave it charging
surface pro 4 overcharge break
will surface bypass battery once fully charged
