Pro 3 getting hot
Discussion in 'Microsoft Surface Help' started by lbetts1968, May 4, 2015.
  1. lbetts1968
    lbetts1968 New Member
    May 4, 2015
    0
    Hi all had my pro 3 for a while now and touch wood the numerous updates are starting to make it behave. I have to ask though it's the i5 version and even when I've got it not doing much. It gets really hot on the back. Is this normal
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Welc0me to the forum
    Hot is a relative term without stats.
  3. hughlle
    Jul 7, 2014
    3,086
    465
    83
    There is a difference between you not having it do very much and windows not having it do very much. There will often be instances of services running in the background using up resources whether this is virus software or windows host executable things. Have you looked at task manager when you find it heating up?
  4. CrippsCorner
    CrippsCorner Well-Known Member
    May 31, 2013
    2,156
    242
    63
    Essex, UK
    SPro
    Are the fans kicking in a lot when it gets really hot?
microsoft surface pro 3 getting hot 2015
surface pro 3 runs hot
