Surface Pro 3 bend, intentional or defect?
Discussion in 'Microsoft Surface Pro 3' started by Flecks, Jan 29, 2015.
  1. Flecks
    Flecks New Member
    Jan 29, 2015
    3
    0
    image.jpg image.jpg image.jpg image.jpg image.jpg So I got my brand new SP3 from the Microsoft store today, took it out of the box, put my screen cover on, and then noticed this and took the photos. It was literally 1 minute old, so I definitely did not cause this, so I'm trying to work out of its meant to be like this or not...
    Please help!
    (Sorry for the photos, really hard to capture though!)
  2. AllTaken
    AllTaken Member
    Oct 28, 2014
    74
    4
    8
    It's not, take it back asap to avoid suspicion.
  3. kevinlevrone
    kevinlevrone Active Member
    Feb 3, 2014
    183
    33
    28
    I know it sounds silly, but what if it's just an optical illusion ? :) Try to see if a gap is forming when attaching a known straight object to the SP3 border.
  4. AllTaken
    AllTaken Member
    Oct 28, 2014
    74
    4
    8
    You can see the glass of the screen is straight, the magnesium housing is not parallel with the glass. It's certainly bent.
  5. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    This has been reported before. The magnesium body was not bended by the use, it came bended. I have not seen any issues reported caused by that. But if you do not feel happy then try exchanging it.
  6. Flecks
    Flecks New Member
    Jan 29, 2015
    3
    0
    Thanks guys, I have already organised a replacement. Getting shipped out tomorrow.
  7. grumpy
    grumpy Active Member
    Dec 12, 2013
    252
    45
    28
    You should return it for a refund and repurchase. If you go through the warranty system, you will get a refurbished unit.
  8. Flecks
    Flecks New Member
    Jan 29, 2015
    3
    0
    Oh really? That's lucky, I actually did get a refund and then repurchased it, but only because that was going to be faster, otherwise I would've done warranty, that's lucky! Aha
  9. ptrkhh
    ptrkhh Active Member
    Nov 15, 2014
    395
    77
    28
    The good thing is at least the bending issue isn't overblown by the media like, you know, the other more popular product.
  10. wynand32
    wynand32 Well-Known Member
    Jun 24, 2014
    1,032
    202
    63
    Oak Park, CA
    I'm still pretty sure this is the plastic strip along the top of the unit (for allowing wireless signals to come and go). Mine's curved as well, and everyone I've seen is that way.
    I do think it's by design.
  11. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Here is the thing. I have seen many pictures like those and never stopped to check if mine is curved or not. To do it I have to remove mine from the case. And that's enough for me let it be. As far as I can see, mine is totally functional and that's what matters to me.
  12. konnexion
    konnexion New Member
    Jan 30, 2015
    3
    0
    Had exactly the same issue. New SP3 delivered on Monday and out of the box I immediately noticed this, boxed it back up and returned it. Replacement arrived yesterday and it's much better. Weird.
bending surface pro 3
bent out of shape surface pro
surface 2 bend
surface bend
surface pro 3 bend
surface pro 3 bending
surface pro 3 bent
surface pro 4 bend
surface pro 4 bending
surface pro 4 bends
