Surface Pro 4 top issues
Discussion in 'Microsoft Surface Pro 4' started by jbowden, Nov 15, 2015.
  1. jbowden
    jbowden Member
    Mar 3, 2013
    75
    17
    8
    1. Display driver crash
    2. Wake from Sleep
    3. Keyboard and touch screen stops responding
    4. WiFi signal speed fluctuation
    5. Battery drain during sleep
    6. Battery draining to fast
    7. Screen flickering
    Microsoft - please fix these issues. SP4 could be a show case for "PC does What?"
    Bi-209 likes this.
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,071
    877
    113
    Norcross, GA
    Personally I'm not having any of those issues on any of the Surface Pro 4s. And they have all been discussed at length on the forum with various degrees of success and a few failures, so far. I think a few of the items on your list are related to your settings.
    The only thing on your list that Microsoft still needs to work on is #1 though I'm not getting crashes at all. I can only assume you have the 9/2 firmware installed after the Th2 upgrade.
  3. jbowden
    jbowden Member
    Mar 3, 2013
    75
    17
    8
    I had those issues on two out of the box SP4 units. I experienced the keyboard track pad not working yesterday on a unit in Best Buy. I can re-produce display driver crash on any SP4.
  4. leeshor
    Jun 19, 2012
    5,071
    877
    113
    Norcross, GA
    I seem to be able to reproduce the display driver issue. I have elected to stay away from it. In my case it's when I used Edge. That's why I separated that out in my post. Using Firefox with the add-ons I have installed I have not seen any driver crashes.
    This IS something Microsoft will likely fix fairly soon.
  5. jbowden
    jbowden Member
    Mar 3, 2013
    75
    17
    8
    If you have hardware acceleration on in Firefox, it will crash the driver more than Edge. With it off, it will not crash.
  6. leeshor
    Jun 19, 2012
    5,071
    877
    113
    Norcross, GA
    No hardware acceleration changes on my Firefox and still steady as a rock. But if that works for you - then great. As far as what you see on display models at BB I wouldn't trust any of those results. No telling who has done what to a demo model.
  7. jbowden
    jbowden Member
    Mar 3, 2013
    75
    17
    8
    If you go to LinkedIn and scroll up/down using Firefox with hardware acceleration on, it will crash.
  8. Peacy
    Peacy New Member
    Nov 14, 2015
    24
    0
    Im having battery draining fast and draining in sleep mode issues, other issues i was having have been addressed..
  9. leeshor
    Jun 19, 2012
    5,071
    877
    113
    Norcross, GA
    Just now tried that. Several scrolls top to bottom and back. Smooth as silk. I think I can credit my extensions for that.
  10. Knuck
    Knuck Member
    Jan 1, 2014
    118
    16
    18
    Not sure how long it will last but I have had no crashes since the major Windows 10 update. I suspect the display drivers were finally updated properly. Prior to the update several display crashes per day.
    No_ax_to_grind likes this.
  11. GatsbyGlen
    GatsbyGlen Member
    Nov 6, 2015
    85
    9
    8
    Battery drain for me during sleep is an obsession, I even think about it when sleeping. Other than that, my SP4 is fine. I should just enjoy it.
  12. leeshor
    Jun 19, 2012
    5,071
    877
    113
    Norcross, GA
    So, it sounds as if you sleep better than your Surface. ;) My sleeping drain is <.05% per hour set to go into sleep mode 60 minutes after closing the tablet.
issues with surface 4
issues with surface pro 4
surface 4 issues
surface 4 pro issues
surface pro 4 forum
surface pro 4 issue
surface pro 4 issues
surface pro 4 issues forum
surface pro 4 problems forum
surface pro 4 top issues
