Wifi connection takes a while to connect after Reboot
Discussion in 'Microsoft Surface Pro 2' started by cdf3, May 10, 2014.
  1. cdf3
    cdf3 Active Member
    Apr 5, 2014
    188
    27
    28
    It takes my Surface Pro 50-60 seconds to connect to my wifi network after Booting Up the device.
    Is this typical?
    I don't have this problem coming out of Sleep Mode. Only if I reboot my device, or Boot Up my device after it has been Shut Down.
  2. CrippsCorner
    CrippsCorner Well-Known Member
    May 31, 2013
    2,156
    242
    63
    Essex, UK
    SPro
    Do you have more than one SSID? Mine used to try to connect to the wrong one first which slowed initial connection down...
  3. cdf3
    cdf3 Active Member
    Apr 5, 2014
    188
    27
    28
    Don't think so. How could I check?
  4. DungeonShredder
    DungeonShredder New Member
    Nov 13, 2013
    38
    2
    0
    Canada
    I have this problem as well
  5. CrippsCorner
    May 31, 2013
    2,156
    242
    63
    Essex, UK
    SPro
    Click on connections and see how many you've got. For instance I have my EE's router connection, my AirPort Express 2.4GHz connection and my AirPort Express 5GHz connection. When mine was taking a while to connect, it was automatically targeting the wrong one... all I did was delete my password from all the connections I didn't want the Surface to try and connect to, and now it goes for the only one it can! It's up within a few seconds of boot now.
    Sorry if I used the word 'connect' too much there :p
  6. cdf3
    cdf3 Active Member
    Apr 5, 2014
    188
    27
    28
    I only have one router. I also have the box checked for it to connect automatically, but it doesn't. I have to manually connect, and it takes over a minute each time
  7. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    You may want to try inputting the IP and DNS info manually into the adapter settings. That should help.
  8. cdf3
    cdf3 Active Member
    Apr 5, 2014
    188
    27
    28
    It was suggested that I uninstall the wifi driver for the Surface Pro. After doing so, I rebooted and it reinstalled the drivers automatically. It's been working fine ever since.
  9. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Great to hear it's working again.
  10. ronvgs
    ronvgs New Member
    Mar 24, 2013
    7
    0
    0
    The Netherlands
    I had the same probleem.
    Uninstaled the driver and now It Works. Thanks
  11. CrippsCorner
    May 31, 2013
    2,156
    242
    63
    Essex, UK
    SPro
    Glad you got this fixed :) but just for future reference, you can have more than one SSID transmitting from a single router...
surface pro 3 recreate ssid each reboot
