Any recommendation for Place to get SP4 battery replaced?
MisterEdF
Definitely ain't paying Micro$oft $489. DIY looks too difficult. Worse case I'll just sell it "as-is"
This might be worth checking out.
Microsoft Surface Pro 4 Battery Replacement | CellPhoneRepair.com
Another possibility is a local repairer just use Google to find battery replacement service near me.
While looking I noticed Newpower99 offers professional service for some devices although the Surface was not specifically listed you might ask them if professional service is available Batteries for Garmin, Magellan, TomTom, Kindle, Palm, Sony, iRiver...
Microsoft Surface Pro 4 Battery Replacement Kit - Extended Life
There is a Surface Pro 4 Battery Replacement guide
Units Removing
Disconnect the two display cables and lift the display assembly up and away from the rest of the device. Remove the metal casing of the connecting panel by prying around the edges and then lifting the entire piece once it is loose. Remove screws on a heat sink and then remove the entire heatsink by lifting it out.
Disconnect cables of a motherboard and remove screws. Then remove accessories and motherboard.
Old Battery Removing
Lift battery cables up with the help of hot air gun. Use the pry piece and 530 cleaner to remove the battery and peel the battery up and away.
New Battery Aligning
Paste double-size glue tape onto the new battery and the battery cable before aligning them to the right place of the device.
Units Installing
Install the motherboard, accessories and the heat sink.
Display Installing
Paste double-size glue tape onto the four edges of the display assembly and connect it with the two display cables on the body of the Surface Pro. Dip some B-7000 glue onto the four edges and align the display assembly to the right place. Then clean it.
Final Test
Power on and test, both screen and battery work normally.
PM - Me - I can tell you how to get your machine replaced if it's still under warranty, which in turn will provide you with a new or "newer", working battery. I won't go blasting off things like this in a public forum, so if your interested, send me a message.
