Battery Wearing for a year
Mine appears to only charge up to 97.2% and has degraded a few percentages in the last 4 months. Not a huge deal, and in real world uses, it seems to only have decreased battery time by 25 minutes.
I'd keep a constant check if you are within warranty. Mine started going gradually down and lots of others too. This is a terrible issue and MS should be doing more about it.
I don't really care anymore, since my 1 year warranty ended September 2015, and I bought it used to begin with, in April 2015.
Guys. Leaving any device with a battery permanently plugged to wall power will shorten the life of the battery. You need to exersize/cycle the battery as much as you can. Every few days just run it down and then immediately charge it back up.
Sent from my SM-N920V using Tapatalk
I had a Macbook for 3 years constantly plugged in at work and when I took it home, the battery worked the entire time and never degraded.
I have discharged the battery once a month and the wear still happened on the SP3. I can see where exactly it occurred. Started around March/April of this year, so roughly 1.5 years since it was purchased.
September 2014, it was registered.
I bought it used in April 2015, so I've had it over a year.
Why can't people accept that it might not be the end user's fault, but sub-par battery manufacturer quality.
Now it's showing 0.0% wear. This is based off of Battery Bar Pro.
Even when I generated a battery report using:
powercfg /batteryreport
At command prompt, it shows that the capacity went back up (normal) in the last few months. I don't get it.
