Dock Firmware and Surface Firmware help
terryj
Hi all,
First post on the forum but recently my work place decided Surfaces are the way forward and we got around 50 of them. So far i'm loving them although they can be a bit quirky at times (especially after the creator update)
But I'm just having some issues with the dock firmware for one, from my understanding it was done automatically by windows updates? yet when I downloaded the new surface dock tool it showed that the firmware was actually out of date. Id rather not have to go around an manually install update.
Also I never actually knew the surfaces had firmware updates themselves (I assumed it was all just windows updates) is there anyway to tell what version of firmware you are currently on and a way to easily deploy any possible updates.
I really appreciate any help or advice given.
