Downlaod and Transfer digital copy movies to Surface Rro for viewing freely
PavtubeVideo
Microsoft Surface Pro have no permission to access digital copy movies. Here comes Pavtube ChewTune software (a DRM Converter app) to help you achieve this goal. The short guide below shows the basic steps on processing conversion between digital copy movies and Microsoft Surface Pro tablet. This digital copy converter program comes in two versions for Windows and Mac platforms respectively. Choose the proper version to have a try:
Note:
* The DRM removing process may mislead your anti-virus software to falsely report virus/worm. Please ignore the report to keep on ripping.
How can I transfer
DRM-protected movies from Digital Copy to Microsoft Surface Pro?
The basic steps:
1. Run Pavtube ChewTune as Digital Copy video to Surface tablet converter. Click “Add video” or “Add from folder” tab to load your Digital Copy movie files that you’ve download onto your hard drive.
2. Select “Microsoft Surface Windows RT H.264 Video (*.mp4)” as output format under “Windows” profile column.
Notes:
1). If you are not using the currently version of Pavtube Digital Copy to Surface Pro Converter, you can go to Profile Patches Page to download a format patch for your Surface Tablet.
2). If you are using the Mac version of Pavtube ChewTune, you can learn how to custom a suitable profile for your Microsoft Surface Pro here.
3. Adjust audio and video settings for output files (Optional)
If you are using Surface RT, you can skip this step. If you are playing videos with Surface Pro, you can click “Settings” button and enter the “Profile Settings” panel to change the video bit rate from 1500 kbps to 2000 kbps.
Best settings for Surface - The universal video and audio settings for both Microsoft Surface Pro
Video
Codec: h264
Size (pix): 1280*720 (720p quality) - If you prefer to watch videos in 1080p quality on Surface Pro, you can set the resolution at 1920*1080.
Bit rate (kbps): 2,000 - If you are expecting a much better image quality, you can adjust the video bit rate higher than 2,000 kbps, but note this would generate videos with larger file size.
Frame Rate (fps): 24
Audio
Codec: aac
Sample Rate (hz) 48,000
Bit rate (bps): 128,000
Channels: Stereo
4. Click “Convert” button to start Digital Copy video to Surface backup. Once the conversion is done, you can click “Open” button to find out the generated MP4 files for viewing on Surface tablet with ease. If you are not quite clear about the steps on transferring videos to Surface Pro, you can learn the details here.
Warnings:
You may meet “"Can't play" error when playing Pavtube converted files on the Surface, that’s because Surface cannot play video files from certain locations. Moving them locally will sort it out.
