Pen bluetooth connection
geckoking
For some reason I go to Bluetooth settings and it shows that the pen is not paired, but it still work as normal.. anyone else getting this?
Keep in mind that BT is used in this Pen only when you click the top button. the rest of the time it should stay disconnected. The pen does not use BT when you are writing.
I had the same problem. I uninstalled the pen, went through the re-paring process and all is fine
My surface has done an update last week. gone to use it again and it says the update only got to 90% and my Bluetooth LE Device on my pen drivers isn't working properly. says it isn't fully installed. anyone know how to fix this? In devices my surface says the pen is there and connected but has a driver error and can't get it to work.... HELP!
