Power Port -- preventing scratches?
whitesleeve
I was thinking of wrapping the metal part of the power plug in perhaps saran wrap or something to prevent further scratching of the power port on the surface -- Has anyone done something like that or other can think of other materials that might work?
I'm still waiting for my Stickerboy, so have employed Sellotape!
Stuck it on over port, give it a slice down the centre with a razor blade, then shove device/charger/cable into port, which forces the tape into the port and covers the edges. Seems to be doing ok so far and doesn't destroy the looks of the device, if you stick it on straight!
