Rotation not working at times?
borka105
Anyone else experiencing times where rotation does not work on the Surface 2? This happens to me almost daily and requires a restart to enable again.
Is it a software issue or a hardware issue?
Thanks
I've noticed this myself recently. Never had this happen on the pro.
It's a pain but i've found that there are two ways to remedy this for now.
If you go to control panel then hardware and sound, select Windows Mobility Center. There is a button there to manually rotate and you can pin to taskbar.
The other way instead of restarting is just to log out and back in.
Those two solutions definitely worked... thank you.
The joys of being one of the original owners of a new product :)
Thanks again.
