Sometimes, I put my SP3 on sleep and it reboot hitself..
And weirdly, when it happened my screen on the left corner doesn't work anymore. I can't select anything with my finger in this zone. (I can with the mouse).
If I reboot again my SP3, the screen works correctly again.
Anyone with the same problem ?
Do you know if it's an hardware problem (won't like that as it means SP3 replacement) or software problem (so I just haveto wait for an update) ?
Thank you for your answer,
