surfdock
Folks, I got the multi-monitor optimizations working for the SP4! Now you can get the same seamless multi-monitor experience with the SP4 that so many loved on the SP3. Download the regkey here:
This will add several 3:2 aspect ratio resolutions to the control panel that you can select from. The alternate resolutions provided in the default install are all 4:3 16:9 and 16:10 aspect ratio which will leave black bars aka letterboxing. The resolutions added with the regkey will use the full screen with no letterboxing so you can be sure you're getting the most out of your screen.
If you're using a dock with your monitors, please let me know how you're using it by filling out a quick survey so I can help improve the experience:
http://www.instant.ly/s/4Ut7b
