Q qwertyy Member Joined Sep 11, 2014 Messages 52 Points 8 Sep 29, 2014 #1 Hi I just got my SP2 today and the pen nib was a bit different from the surface pro 3 pen, which was made of rubber. Do these surface pro 2 pen nibs wear out as well? Also, where can I get the replacement nibs just in case?
jnjroach Administrator Staff member Joined Nov 9, 2012 Messages 8,064 Points 113 Location Seattle, WA USA My Device SurfaceProX Sep 29, 2014 #2 Wacom has replacement Nibs, look for those that are compatible with the Bamboo Feel Stylus.... IIRC Amazon has them available as well....
H horseflesh Member Joined Mar 21, 2014 Messages 55 Points 8 Sep 29, 2014 #3 I got the rubber-tipped replacement and I like it. It provides a little more drag than the OEM hard plastic tip.
OP OP Q qwertyy Member Joined Sep 11, 2014 Messages 52 Points 8 Sep 29, 2014 #4 horseflesh said: I got the rubber-tipped replacement and I like it. It provides a little more drag than the OEM hard plastic tip. Click to expand... Where did you get it from? Does Microsoft offer those for free?
