Surface Pro Studio 2 - Turn of Display Screen only
playfuljay
Other
I would like to know how I can turn off the screen only on my surface pro studio 2, WIndows update is IOS 2004. Ideally, I would like to be able to press the on/off button on the side to just turn the screen off ( required PC to keep running)
@playfuljay, This is something that Windows 10 and Surface computers should provide, but still don't.
There is an inexpensive software utility called NirCmd which you may wish to obtain. With one command, the screen can be turned off. Search for NirCmd.
