Track pad custom gestures
mr.dj26
Hey guys,
Its been a long time since I visited the site:p
Anyways, I am using Touchme Gesture with Dexpot and it great, I just need to modify the track pad gestures to make it work with the other apps.
I Cant find the right manufacture for the track pad.
I tried Synaptics - Windows 8 (32-bit/64-bit) but its not working. Is there any app that can modify the sp3 trackpad gestures?
Thanks
Microsoft is the manufacturer of the trackpad....
Thanks for the reply.
But is there anyway to modify the gestures, I searched but I cant Find anything, and I also didn't find any drivers that can be customized.
I'm not sure what compatibility third party software has, but I do know that Windows 10 will add gesture support....
Hey! this is actually my first post, so yay me... but there is a great app on the store called "Touchme Gesture Studio". Basically it enables you to create a bunch of gestures for your touchscreen, if that is something that you are interested in. I know it does cost a bit of money after the free trial but it has worked great for me. You must install the engine from the link within the app
I would also love for a touchpad gesture option, something similar to BetterTouchTool for OSX.
Hey, welcome to the forum :D
I have mentioned the touch me gesture app in the first post and it's great but I would like to use those gestures from the trackpad when using the sp3 as a laptop.
Thanks for the feedback guys
