Snake Doctor
If I need a new wireless card do I have to send my Surface Pro2 in to Microsoft or can it be replaced at a pc repair shop?
Or you could go with a USB wireless adapter which might be a lot less hassle... maybe.
Max 430mbps 5ghz only AC450 Nano USB
Amazon.com: TP-LINK Wireless AC450 Nano USB Adapter, 5Ghz Only, Backward Compatible With 802.11a/n, Supports Windows XP/Vista/7/8/8.1/10/Linux/Mac OS X 10.7-10.10 (Archer T1U): Computers & Accessories
Max 866 mbps dual band 2.4 & 5 ghz AC1200 (it's big and you'll bend it)
Amazon.com: Linksys Dual-Band AC1200 Wireless USB 3.0 Adapter (WUSB6300): Computers & Accessories
Max 430mbps dual band AC580 Mini USB
You can disable a Network adapter in Device Manager or Control Panel - Network Sharing Center - Change Adapter Settings.GreyFox7, I like your idea and I wouldn't be without my tablet for 3 or 4 weeks. How would I disable the current adaptor, wouldn't there be a conflict?
I'm not surprised but depending on the condition of your built in adapter it might act up from time to time. Thus to be safe I'd still disable it somewhere, assuming it even shows up.Actually, I just put the USB wireless adapter in and windows 10 took care of everything else. How wonderful!!! I feel like I have a new machine. From everything I have read, it seems as if all Surface PRO's are having wireless issues. IPad doesn't ..... what is MS doing about their issues?
