Solved External hard drives run on after SP3 power down
Discussion in 'Microsoft Surface Pro 3' started by GrumpyBadger, Apr 5, 2016.
  1. GrumpyBadger
    GrumpyBadger New Member
    Apr 5, 2016
    3
    0
    I have two external USB hard drives connected to my SP3 through the brick dock (not the docking station). When I turn off the SP3, the hard drives continue to run on the dock power. How does one get them to shut down and stay down? I would have thought they would shut down when I shut down the SP3.
    Appreciate any help... I tried a search here, but apparently I didn't hit the right key words.
  2. GrumpyBadger
    Apr 5, 2016
    3
    0
    Never mind... now that I wrote this post, a relevant earlier post popped up in similar threads. I have my answer.
    Thanks!
  3. Telstar1948
    Telstar1948 Active Member
    Jul 12, 2013
    435
    79
    28
    Columbia, Missouri
    Surface Book
    So...what was the answer?
  4. GrumpyBadger
    Apr 5, 2016
    3
    0
    thread: USB power on dock after shut down
    Based on what I presume is someone else's expertise as discussed in the reference thread, the Surface dock 'brick' apparently functions as a powered USB hub... the power to the USB drives doesn't shut down as long as the dock is plugged into a power source. I assumed that the dock should shut things down when the computer is shut down. It does not because the dock functions as a powered hub and does not take a power shut off command from the computer.
    I guess... that's how I interpreted it anyway. That make sense?
