Just received my surface pro. Puzzled.
Discussion in 'Microsoft Surface General Discussion' started by resle, Apr 5, 2013.
  1. resle
    resle New Member
    Apr 5, 2013
    4
    0
    0
    So, I've just received my surface pro. 128gb, type cover, etc.
    What puzzles me is a quick comparison of stylus input with my previous tablet pc: a Fujitsu Stylistic 5010ST which I still own today.
    The Stylistic is hardware from the distant year 2005, sporting 1gb ram and a pathetic single core pentium M 800mhz, and a GM Intel chipset. Specs that are somewhat inferior to a modern smartphone. In time I upgraded this machine to Windows 7 and, recently, to Windows 8.
    Well, even with those specs, the Stylistic is still much, MUCH better than the surface pro in terms of stylus input. Precision, pressure sensitivity, and most important of all input lag - all are incomparable using Sketchbook pro, note taking software, or even just clicking around.
    If there's some other tablet pc veteran here, am I having some issue with my Surface Pro, or is your experience the same?
    Thanks
    r.
  2. derausgewanderte
    derausgewanderte Member
    Dec 29, 2012
    80
    8
    8
    I tried the Pro in an MS store and I loved the response of the pen and its feel. There was no lag and it was very accurate. Much better than what we have on the RT of course. If you find you have lag and it's not accurate I would say that something might not be OK with yours. But again, I only tried the Pro in the store and own the RT. Hope a Pro owner can shed some more light onto this for you. good luck, hope you can get it fixed soon.
    cheers
  3. tonyz3
    tonyz3 New Member
    Jan 28, 2013
    729
    118
    0
    I had a fits q702 before the pro and my pro is better. I did like the q702 but it lack necessary drivers. Have you tried calibrating the pen.
  4. resle
    resle New Member
    Apr 5, 2013
    4
    0
    0
    I did several rounds of very careful calibration but, nothing.
    Mind well: the surface pro is excellent. Lag is very low.
    But still uncomparable to the near-zero lag of my old old old stylistic...
  5. FFX
    FFX Active Member
    Dec 23, 2012
    226
    25
    28
    Sweden
    S2
    Did you run all of the updates? Maybe you could try to do a reset.
  6. machistmo
    machistmo Active Member
    Nov 17, 2012
    791
    53
    28
    Raleigh NC
    Other
    Quoted from Dartesian in a different thread:
    You might try:
    Reset any existing calibration in Tablet PC settings.
    Press Win key, type "Run"
    Copy and paste the following into the Run window:
    tabcal lincal novalidate XGridPts=10,60,110,360,660,960,1260,1560,1860,1910 YGridPts=10,60,170,330,490,650,810,970,1020,1070
    Run the command, allow permissions, go through the calibration. This makes for near perfect pen accuracy, but it's never going to be perfect. Corners will still be messed up, but that's how it works, apparently. More X and Y points can be added to the lists for even more precision. Each number just corresponds to the X or Y coordinate of a pixel on the screen.
    Source: Improved Pen Accuracy with a 100 Point Calibration Grid : Surface
    This fixed all my problems I held the stylus normally and it works perfectly in every part of the screen (minor corner issues seem to be unavoidable)​
  7. resle
    resle New Member
    Apr 5, 2013
    4
    0
    0
    Thanks for the suggestion. It helped a lot, precision has improved dramatically. Lag is still present - I've been told on another forum that this is due to the adoption of a capacitive rather than resistive digitizer, and that the latter allows for greater responsivity. So be it :\
  8. machistmo
    Nov 17, 2012
    791
    53
    28
    Raleigh NC
    Other
    The forum in my above post may also have some more detailed information. I am pretty sure that the lag you are feeling is due to the nature of what you are trying to do with the Surface. I am not sure I was designed for the applications you want to use. That being said, lets hope a driver update can get some more responsive behavior out of it. I've seen some videos of the surface being used for inking and it seemed pretty responsive but I could see how someone that used a professional drawing tablet and a PC might find it sluggish. Beats finger painting on the iPad though right?
  9. TagsxA
    TagsxA Member
    Mar 31, 2013
    71
    2
    8
    Wisconsin
    Surface Book
    ...or even painting with an iPad "stylus". I've spent around $100 on styli for my iPad 3rd gen and none have lasted longer than a few weeks. My problem is that unless I diligently clean the surface of the iPad, the rubber-tipped styli just soak up any and all hand residue and then cause the tip to have unnecessary drag across the screen. Sooooooo frustrating :(
  10. resle
    resle New Member
    Apr 5, 2013
    4
    0
    0
    Well, the Stylistic wasn't designed for that kind of applications either - infact, it was even made 2 years before Sketchbook Pro existed (and I also run Sketchbook Pro 2011 + Windows 8 equally greatly on it). It's the comparison which sounds strange to me, as the Stylistic is literally dwarved by the Surface Pro, but performs much better in terms of stylus input. 8 years older (!!!). So, its advantage must be in the touchscreen technology, there is no other explanation..
  11. Tom T
    Tom T New Member
    Jun 25, 2012
    146
    14
    0
    RT
    I also used to have a good pen based tablet and the main difference was it was dedicated to pen input, rather than a digitizer layer mated to a capacitive screen. Really my old tablet had a very high resolution digitizer, and I don't believe this is the purpose of the Wacom Feel IT technology. For what it does though I love this new tech.
calibrate sketchbook pro
microsoft surface pro3 pen lag
microsoftsurface touchpad clibration
sketchbook pro calibration
surface pen lag
surface pro 3 pen lag
surface pro pen lag
surface pro stylus lag
surface rt touchpad lag
surface update sketchbook pro
