Power cover bug
Discussion in 'Microsoft Surface Pro' started by skellington, Jun 23, 2014.
  1. skellington
    skellington Member
    Jan 27, 2014
    59
    13
    6
    Just got one to improve battery life, and it shows up in the battery icon, and charges to 100% but when I run off AC power, the main battery is consumed first and just dies after it goes to 0.
    I guess I can play the reset, update driver, etc.. game again but the number of bugs on SP is getting old. They still haven't fixed all of the sleep bugs...
    Anyone else seeing this behavior from the power cover?
  2. kodos
    kodos Member
    Dec 24, 2013
    84
    14
    8
    Nope, haven't seen this behavior yet. Maybe I don't understand you, but are you saying that when plugged into AC power it is consuming your main battery?
  3. jnjroach
    Nov 9, 2012
    7,587
    1,810
    113
    Seattle, WA USA
    SPro
    sorry your description of the issue is a little confusing. If you are saying that the Power Cover keeps the main battery at 100% until its battery is depilated and then the main battery kick' in then it is working as designed.
  4. skellington
    skellington Member
    Jan 27, 2014
    59
    13
    6
    Sorry...
    Both batteries show up as battery #1 and #2. I'm not sure which one is the power cover vs the internal, but when I unplugged the SP, one of the batteries drained to zero (I forget which one). At that point, the SP turned itself off. So, the SP drained the internal battery before using the power cover (and didn't switch to the power cover).
    It's like the SP sees both batteries, but doesn't drain them in the correct order.
  5. jnjroach
    Nov 9, 2012
    7,587
    1,810
    113
    Seattle, WA USA
    SPro
    Battery One is the SP2 and Battery 2 is the cover. Have installed the latest firmware update?
  6. skellington
    skellington Member
    Jan 27, 2014
    59
    13
    6
    Installed latest firmware? Who knows...
    I have everything up to latest according to the system updates app. It's entirely possible that the firmware isn't up to latest for some reason, but this is the kind of junk that makes me hate the SP. It's not my job to debug everything. MS makes the hardware and the software, can't they get updates to work correctly automatically?
  7. mennogreg
    mennogreg Active Member
    Dec 24, 2013
    188
    32
    28
    Occasionally I've seen my SP1 with Power Cover not read the power cover's battery (though keyboard itself works) if I fold it back, particularly it goes to sleep while that has occurred. Doesn't happen all the time, but something I noticed. Maybe that's what you're witnessing?
    As for firmware, the SP2 has a more recent power cover update that has yet to make its way to the SP1.
  8. skellington
    skellington Member
    Jan 27, 2014
    59
    13
    6
    Interesting.
    Both batteries show up for me and both charged to 100% so the SP correctly charged the 2nd battery, but when running off the batteries it drained the SP battery first (and then died). At this point I've given up on the battery cover since I don't care to spend any more time trying to debug it (and as it turns out, it's heavy as hell and I don't care for that either).
    Thanks for the suggestions.
  9. sdreamer
    sdreamer Member
    Mar 23, 2014
    62
    10
    8
    Happened to me the other day. Quick restart fixed it for anyone that might run into this. Removing and reattaching the cover didn't work.
  10. drolem
    drolem Active Member
    Aug 9, 2013
    293
    36
    28
    98052
    Try these in order if restart doesn't help: (do the 2nd one only if the 1st doesn't fix it)
    1) remove power cover, turn off SP while no charger is attached, wait about 20 mins, turn on SP, attach power cover when it's fully on
    2) remove power cover, remove charger, do a hard reset, turn on SP, attach power cover when it's fully on
  11. toaf
    toaf Member
    Jul 9, 2014
    231
    22
    18
    infront of my surface you silly person
    SPro2
    try doing the update with it cover plugged in. i had the same issue once on a sp2 or maybe it was a firmware update while the power cover was plugged in
how to reset surface 2 power cover
how to reset surface power cover battery
surface power cover firmware
surface power cover firmware bug
surface power reset
surface pro 4 power cover
surface pro charging bug
surface pro power cover bug
surface pro power cover reset battery
surface pro users forum
