Surface Pro not openning Illustrator files
Discussion in 'Microsoft Surface Help' started by sparler, May 18, 2014.
  1. sparler
    sparler New Member
    May 18, 2014
    5
    0
    Just got a Surface Pro. Installed Adobe CC. Can't open illustrator cs6 files that were created on a mac. They are housed on Dropbox. Tried downloading... got same error. File type is incorrect or file is correct. Ideas?
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Are they EPS files and did you save them on the MAC with TIFF preview? If they are AI files there shouldn't be any issue. You may want to refer to the Adobe forum,s as I doubt the problem is your Surface.
    btw: Changing your title for you from Pirface to Surface. ;)
  3. sparler
    sparler New Member
    May 18, 2014
    5
    0
    They are Ai. I will post at adobe as well. And thanks for changing my spelling. That's what you get typing on a train.
    1 person likes this.
  4. sparler
    sparler New Member
    May 18, 2014
    5
    0
    Update: I now believe the issue is with Dropbox. Not illustrator or excel. Dropbox is failing to download files to the surface pro desktop. I get the error file transfer failed. I have send Dropbox a request for help.
  5. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    I was thinking that might be a part of the problem though I don't know why. What version of DB are you using?
can you open adobe illustrator files on surface pro on a mac
eps file on a surface pro 3
how to open eps files on surface pro
how to open esp files on surface pro
open eps files surface 2
