Surface Pro with Screen Lift Issues
Discussion in 'Microsoft Surface Pro' started by will25u, Jul 15, 2013.
  1. will25u
    will25u New Member
    Apr 12, 2013
    2
    0
    Seems like I've had the worst of luck. The first surface I received had a bad speaker that was making this crackling sound. The replacement is now having this screen lifting issue. The bottom of the screen is not sitting flush with the surface casing right where the windows button is located. The screen lift is causing a gap that is large enough to stick a paper right through and enough for me to stick my finger nail in if I wanted to. I tried to use clamps to fix this and it worked for about 2 days but when the surface heats up then the screen lifts up again. Is anyone having a similar problem like this?
  2. Igor
    Igor New Member
    Jun 3, 2013
    55
    18
    0
    I have not had this issue but I have come across a couple of stories like this. I thought it was just an issue on the early batch of SPs.
    If I were you I would just get it replaced until you get a good one. You've certainly had bad luck but that's what the warranty is for right?
screen lifting surface pro
surface pro 2
surface pro 2 screen issue
surface pro 3 screen is lifting
surface pro 3 screen lift
surface pro 3 screen lifting
surface pro 3 screen problems
surface pro screen lift
surface pro screen lifting
surface pro screen problem
