System Devices Not Starting
Discussion in 'Microsoft Surface Pro 4' started by gtmead09, Nov 5, 2015.
  1. gtmead09
    gtmead09 Member
    Oct 31, 2015
    50
    7
    8
    In device manager under system devices, I have one called "Surface Touch Serviving ML" which is showing that it cannot start. When I attempt to update the driver, it says it is the latest version. Am I the only one on this one? I tried multiple ways to get it going but no luck. Thanks
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Did you apply the 11/2 firmware update.
  3. gtmead09
    gtmead09 Member
    Oct 31, 2015
    50
    7
    8
    Yes, still happening.
  4. gtmead09
    gtmead09 Member
    Oct 31, 2015
    50
    7
    8
    If I remove the device in device mgr and rescan, it says it installs and is working properly. I reboot, it goes back to cannot start / object name not found
  5. gtmead09
    gtmead09 Member
    Oct 31, 2015
    50
    7
    8
    Driver 1.0.2.0, dated 8/30/15
  6. gtmead09
    gtmead09 Member
    Oct 31, 2015
    50
    7
    8
    Called MS, their suggestion was wait for upcoming update even with the newest firmware
  7. jrg63
    jrg63 New Member
    Oct 28, 2013
    6
    0
    I have exactly the same issue. Deleting and reinstalling the driver doesn't fix it as the problems goes away until the next reboot. I have a SB 256/i7/dgpu. I received mine on Oct 26 so it's one of the early ones.
  8. gtmead09
    gtmead09 Member
    Oct 31, 2015
    50
    7
    8
    Mine is the 256, i5, 8 GB
