Solved an offset between cursor and nib
1mrpaul1
Surface 3 (Atom)
I t is very pleasant to draw on surface 3 but when you holding the pen by angle cursor goes under the pen, this is bad because you can't see where are you pressing and also you re drawing not in those place where you expected, bigger angle gives bigger offset,
another problem it, when working in illustrator or photoshop, it is very hard to click on the smal UI elements as sliders, it is very frustrating
so, is it possible to correct cursor position?
Welcome to the forum
Have you checked out the "Surface" app. There are some pen tools there. You can calibrate or reset the calibration and s sensitivity.
I searched everywhere but can't find it
In surface app I have just pressure set up, win button and sound quality
I remember calibration settings. I saw it when just bought the device but it is disappear after driver and firmware update probably.
May be I can open this setting through run command?
found a solution
it was windows 10 bug. mobile PC setting are gone.
I open it trough code
Go to the Desktop.
Right click on the Desktop and select New/Shortcut.
In the Type the location of the item window, Copy/Paste the following.
%windir%\explorer.exe shell:::{80F3F1D5-FECA-45F3-BC32-752C152E456E}
Click the Next button and type the name Tablet PC Settings.
now every thing is fine
Or you can right click on Start button and open Control Panel and get Tablet PC Settings there.
i d0 n0t have tablet pc settings and got to open it only by means of code
