As anyone done a System restore using a USB hard drive
Bazzer
To stop having to go back to Windows 8 every time you do a refresh is there a way of dumping the SS Hard drive to a large USB stick?
Sure, no problem. I'm using Acronis True Image as imaging software to create backups.
After getting a replacement device it was no problem to restore the backup from the previous device. I just had to perform the Windows activation and everything was up and running again.
Good luck,
Robert.
