Best Custom power plan?
swanlee
So my son broke my trusty Surface pro, luckily I did the extend warranty plan so MS replaced it but not all my setting transferred over. I had a custom power plan that worked well but can;t find it.
So what are the best options to change to get the most battery life?
I've already adjust the MAX cpu to 80% but I remeber changing a few more options to get better batter life.
I think the best setting to edit is Intel Graphic power plan . If you use the Version from Intel website you can edit it with the Intel Control Panel . Else If you run the MS Version edit this setting in change plan settings > change advanced power settings
Nice link! I've created that power plan I'll check how it works.
