Can I charge my US Surface with Italian power?
vignuol
Surface 3 (Atom)
Hi guys,
I bought a Surface in the US and now I've just come back to Italy for holidays. I forgot my adapter though:(, and I wonder whether I can use a standard European USB charger to charge my Surface 3.
Thank in upfront
Antonio!!
As far as I know: USB=USB. So, yes. With the right plugs attached to your adapter you could even use your own adapter I guess.
But if you're there for the holidays, you know people. Just check voltage and amperage and you're good to go
I bought mine last year in the states and Iam using it in Germany with several different adapters, all are working fine
Gesendet von meinem Mi-4c mit Tapatalk
Yep, that will work.
For good results try to find a USB charger that will supply 2.4A, 12W.
Good thing USB wasn't developed by the entertainment industry, they would have hardcoded the plugs to the respective countries. :p
When I go back to the States in the summer, I use an adapter to charge my Surface 2, which I bought in Spain, and it works fine.
