Driver Power State Failure
Danja
Hello,
I have a <1 month old Surface Pro and for the last few days it's been crashing while sleeping. For some reason WhoCrashed only sees the event that occurred overnight, although a similar crash happened a couple days ago. The WhoCrashed report is below. Does anyone have any suggestions to troubleshoot?
On Sun 5/10/2015 6:23:04 PM GMT your computer crashedcrash dump file: C:\windows\Minidump\051015-7046-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x150CA0)
Bugcheck code: 0x9F (0x3, 0xFFFFE0000D438060, 0xFFFFD000B387F960, 0xFFFFE0000EEBCCF0)
Error: DRIVER_POWER_STATE_FAILUREfile path: C:\windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporationdescription: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Hello,
Hi, welcome to the forum.
A few questions. Is your machine a Surface Pro, or a Surface Pro 3?
Does it happen when it's plugged into power, on battery, or both?
Have you tried refreshing, or restoring, your Surface?
Please let us know!
Same error since windows 10 (fresh install)
ntoskrnl.exe+152c76
DRIVER_POWER_STATE_FAILURE 0x0000009f
any idea or way to find out what driver or device cause this?
