Edge anomaly
Tsurugaya
This is a bit odd. When starting Edge on the SP3 and typing a few letters for a site I usually visit, suggestions start to appear. If I use the mouse to click the one I need, nothing happens. If I use the cursor and Enter key, it works fine. However, this exact problem does not occur on my Windows 10 tablets, only on the SP3 and with a Bluetooth mouse.
It sounds on the surface, (no pun), that you aren't connected to the Internet. Does it only happen when you're using the mouse?
Yes, using arrow keys or tapping works fine, but the mouse causes no reaction.
