Edge won't start
Steeli
Hello
We have 24 Surface Pro4 running in our Domain. Every Second unit has Problems that Edge open and close... i tried differnt reparations in Command Line. Sometimes it worked and sometimes the Problem still exist after reboot. It get me really angry at the Moment :-(
Matthias
Matthias,
Let's try to help.
1) Does Internet Explorer work okay on all machines? Start Internet Explorer on each one, browse a bit, then close. Edge shares some Internet settings with the Internet Explorer in the Registry.
2) Could you be having an IPv6 issue? Depending upon the timing of your initial configuration of those machines, there may be conflicts with IPv6 addresses. Visit the adapter properties and disable IPv6. Then try to start Edge. Re-enable IPv6 while connected.
