HELP Me - My right sidebar doesn't work
cauzion
I don't know why, but suddenly my right sidebar (share/config/etc) doesn't appear when I slide my finger.
I have my surface RT for 2 months and had no problem till now.
Please, anyone who could help me here ???
Carlos
Brazil
what does restore means ?? There's no backup utility on Surface ? Will I lost installed applications and data on refreshing my Surface ?
Thanks,
Carlos
Thanks,
Carlos
Restore will not erase your files. Check the link above for info and directions.
@cauzion, can we do this first? If you have a keyboard, place the mouse pointer to the upper right corner, and see if it appears.
Delete the touch screen calibration. When I calibrated mine, it made my charms screen only open if I swiped from the center of the screen. Deleting it fixed my problem. (I must have done a bad job calibrating)
Well, I did an Installation Refresh and it worked. Have no time to test with other posted suggestions. Thanks you all guys !
