Looks like it has the tray at the bottom, but how can you tell it from the device manager, and how do you tell if there is a sim card is there already or not ( other than opening the tray) I want to check through Win 10.
left side of where the keyboard connects, abut one inch to the corner, there is a tray with a small hole on the right side of it.
If you see " Surface modem device " in the device manager, then you have a modem. Additionally, when you go into Settings > Network & Internet, you should see options for your LTE connection. This is only available for devices with LTE firmware. If you have the LTE firmware, then you have an LTE device. However, as others have mentioned, get a paperclip, or the supplied tray opener, and open the tray and find out![]()
I didnt know because the seller didnt mention it. Yes, there must be a SIM card there because it never gave any messages. But does having a SIM card makes a difference if I am not with ATT ( I am with Boost)?So, it looks like you got an LTE version. As it is about $ 100,- more expensive I am wondering how come you didn't know?
I think if there is no SIM card the software will mention that as soon as you activate the modem.
