is surface pro 3 type cover compatible with surface 3?
nav
Surface 3 (Atom)
I have a surface 3 and want to purchase the type cover, but my local store in Vietnam doesn't have it. They only have surface pro 3 type cover model, which is known to be larger than the one I want to buy. I do not mind the dimension difference but can the type cover for surface pro 3 be used with my surface 3? (specifically the mount point)
On a side note, I know this is kind of weird but I have no option to buy the right type cover model. And the store does not have display sample so I cannot try.
Welcome Nav. Any reason you cannot simply buy one off the internet?
But yes, the SP3 typecover will work with the S3. If i recall correctly, the magnetic strip will not work allowing for the raised typing position, only allowing for it to lie flat on the table (which I personally cannot stand).
thanks hughile.
I bought one online and it went missing in custom inspection, and I don't want to try again, that sucks :(
