Yes. Open IE . At the top of the window right click to provide a selection menu and choose Favorites bar.View attachment 4964
Is there a way to have a favorites bar like I have circled below from my IPad using IE? It allows you to have easy access to your most visited sites
You can also change the mui IE options to always show this bar, so you're just one tap away from favourites.Assuming you specifically want a "Bar" placed in the browser at that specific spot that can only be done with Desktop IE. However in MUI IE if you swipe up from the bottom you can access most frequented and Favorites, for anyone that hasn't discovered it yet.![]()
