Problem Updating Surface Pro 3
Gegech
Hello,
I just got a Surface pro 3 and I see in the forum that there is a new Firmware.
I guess I just have to do a Windows Update on my Surface?
But I get the message "Error 80072EFE" cannot update.
Don't know what is wrong, I turned off my Firewall etc.
Thank you for your help
Hello,
You should see a link to follow for details of the error... running the troubleshooter from the linked page often times will fix the problem.
Thank you for the help,
I did try that, but I could not do it, will try later again.
I had an issue yesterday and the troubleshooter fixed it BUT I had to reboot before it worked which was not indicated.
