S3 issues with 64GB MSD card
JOEBOB69
Surface 3 (Atom)
Right after i bought the Surface 3 i bought a 64GB micro sd card to go with it. It was working perfectly with no problems for a few months. Then about a month ago it will not save any new items, exp. docs, pics, music etc. It also will not let me delete these items.
Now when i first add a file, it will show up. The same goes for when i delete a file, it will show it gone. When i restart the surface it is like nothing happened. It is like it is locked the way it was a few months ago.
Any help on this ?
Welcome to the forum
2 suggestions. Do a disk test/check on the card. And try it using a USB adapter on your PC to see if it looks like it'd doing the same thing. It may just be corrupted but SD cards do go bad.
