Scaling Problem
MarkusH91
Hey guys,
I have a Problem. I installed a few programs like SAP and the scaling is very bad. The programs are shown very tiny, so you can't read anything.
Do you may have a solution?
Thanks!
Locate the actual application file (.exe) -> Right click the application (not the shortcut) and select "Properties" -> Select the "Compatibility" tab -> Check the option "Disable display scaling on high DPI settings".
Sometimes I found this to solve that problem.
