SP3 - Help me choose mouse and HDMI adapter?
CC268
Is the Surface Pro 2 HDMI connector compatible with the Surface Pro 3 or do they use different connections?
sp3 has a display port. it does not have a hdmi.
My signature has links to what I have purchased for my sp3 which may help.
The Surface brand Mini-DisplayPort -> HDMI adapter F6U-00011 is compatible with both Surface Pro 2 and Surface Pro 3. I believe it is also compatible with Surface Pro 1.
For desktop use, I would get the Accell brand adapter from Amazon. I believe it costs less and supports slightly higher frequencies than the Surface brand.
http://www.amazon.com/Accell-B086B-007B-2-Active-Adapter-Packaging/dp/B00F90H77A
The key advantage of the Surface brand adapter is its durability. The materials are far superior to the others and it will probably last a lot longer IMHO, so if you are frequently going to throw this in a backpack with your Pro, then get the Surface brand one.
I am trying to find a nice one that supports 4K...so far the only one is Cable Matters
