Surface 2 HDMI display problems
Canuck
Hi everyone,
I have an odd problem. I hooked up my Surface to my Toshiba TV using the Microsoft adapter and it worked perfectly.
I then tried it on my Hitachi Plasma HDTV and the TV doesn't see it. The surface acts like the TV is seeing it, but the message I get on the TV is "No Sync - No Signal". I couldn't seem to find anything in either the TV's settings or the Surface settings to make the TV and Surface play nice together.
Anyone have any thoughts on how to solve this problem?
Thanks
Brian
Welcome to the forum Brian
I have 2 suggestions. Restart your Surface with it plugged into the TV, and try cycling the HDMI inputs (on the TV)
I've seen some reports of older TVs not recognizing the Surface 2's HDMI Connection, for some lowering the resolution to 1280x720 fixed it because the TV was using interlaced (1080i).
That sounds like it may be the case. Do you think lowering the display settings on the Surface would make a difference?
Tried doing both those things - with no luck.
Thanks
I've seen it work on some other TVs, another option that might work is 1024x768 that way MUI Apps will work.
