Surface Pro 2 HP Printer Driver
Terry Kemple
I'm new and have not used a forum before and am not even sure how to look for responses.
I'm trying to install a network HP Color Laserjet 1215 on the SP2. Downloaded the driver from HP but when i click "install" the installer can't find the driver. I can find the file downloaded from hp but can't find where it's unpacked when it's executed.
Welcome to the forum
There is a search bar top right that may help going forward.
Normally when extracting HP drivers it should run the setup program after extracting. The extraction location may be hidden in a temp folder under \users\(user name)\appdata\local\temp. In order to view that location go to file explorer in the control panel and check show hidden folders under the view tab.
