P pm69 New Member Joined Mar 28, 2014 Messages 2 Points 1 Mar 28, 2014 #1 Hi guys new member does it do 4k like the surface pro 2? Thanks
ScottyS Active Member Joined Apr 14, 2013 Messages 774 Points 43 Location New York My Device SPro7 Apr 5, 2014 #2 If you are referring to the mini display port's screen resolution output, it's 2560 x 1440 on SP and 3840 x 2160 on the SP2.
I icemanmelb New Member Joined Mar 17, 2014 Messages 3 Points 1 Apr 6, 2014 #3 according to this link: UltraAV® Mini DisplayPort 1.2 MST Multi-Display Hub http://www.accellcables.com/media/products/DisplayPort/msthub_res.jpg you can do 4k on the original displayport 1.1a but only on 30 hz Last edited: Apr 6, 2014
spinachpie Member Joined Apr 25, 2014 Messages 144 Points 18 Jun 5, 2014 #4 icemanmelb said: according to this link: UltraAV® Mini DisplayPort 1.2 MST Multi-Display Hub http://www.accellcables.com/media/products/DisplayPort/msthub_res.jpg you can do 4k on the original displayport 1.1a but only on 30 hz Click to expand... Has anyone been able to confirm this? Really want to know before buying a 4K set
spinachpie Member Joined Apr 25, 2014 Messages 144 Points 18 Jun 5, 2014 #5 Just been chatting to a MS tech who quoted this: As I have checked my resources here, the maximum resolution that the Surface Pro will output at 60Hz is 3200x2000
