Surface pro 7-8-9 comparison
ArieBos
I am thinking of buying a new surface pro, but does anybody know a good comparison between the models?
I saw an Asus laptop with an i9 processor. Does that exist in Surface Pro?
Plantje
I don't think an i9 option exists for the the surface pro. Main difference between 7 on one hand and 8/9 on the other is the screen.
I would recommend checking some YouTube videos in which all versions get reviewed. Those have all been made over the years
A
ArieBos
Thank you, will try to find some of those. The surface is too expensive to make a decision lightly.
Plantje
That's exactly my idea. Recently my Surface Pro 2017 Advanced LTE started throwing this many BSODs that I have to consider it broken. I am also looking for a replacement. Don't need the latest and greatest, so currently I am looking for second hand Surface Pro X, Surface Pro 8 or one of the Samsung Tab S8 flavors.
To be honest: I am currently testing a Samsung Tab A 2019. It is sluggish as hell, but apart from that Android is treating me quite well!
A
ArieBos
Well, I need a windows machine for work... thinking of the SP 32GB/1Tb version. Strangely enough, nobody sells the beautiful green version here in the Netherlands.... only graphite and platinum..
Plantje
I also always thought I need a Windows machine for work, but nowadays I am more and more convinced that an Android device fits my needs. Enrolling a privately owned Android device in our company's device management is way easier than enrolling a Windows device. I always thought I was on the safe side as for work we also use Windows devices.
True in green the most advanced version you can order is a 16GB/512GB i7 variant.
