Surface pro charging issues
Recens
Hi,
I have a problem with my surface pros (I have three of them). When they are working everything is fine.
But once in a while they stop charging and go into sleep mode even though they're plugged in, when waking them up the tablets aren't charging but if I unplug them from the wall socket and plug them back in then they start to charge again.
Has anyone had a similar problem.
If anyone has a solution on how to resolve this problem that would be appreciated.
Hi,
You have 3 surface pro's and all stopped charging and went to sleep mode. This happens to me as well but only for single device not for all. Actually this also happens to me because of the issues in extension board. You should also check that one.
