Surface RT and AMB Labs USB DAC
ArnoldC
Makati, Philippines
I built a couple of headphone amps and USB DAC from AMB Laboratories AMB Laboratories DIY Audio Site in the past and I'm glad the USB DAC works with the Surface. I can now use the Surface to play my high-bit rate audio files through DAC, or DAC + NAIM Headphone amp, or DAC to my main audio system built on NAIM integrated amplifier and high-efficiency speakers.
Yes!
Nice - I've considered a project like this a few times. I use a FiiO DAC/Amp on my desktop at work - I should try that on the Surface and see if it works...
It works. Plugged in the FiiO E7 DAC/AMP, Windows picked it up and knew exactly what to do with it. I need to do some comparisons to see how much improvement I'm getting - the DAC in the Surface isn't too shabby.
[TABLE="width: 500"]
[TR]
[TD]Next level...
[/TD]
[TD][/TD]
[/TR]
[TR]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Yeah, I had the same experience with my Burson HD160DS - pleased to see the RT picked it up immediately. That's when I was smitten and the iPad went into the drawer.
Nice! I've been thinking about upgrading to a nicer DAC, but I'm pretty happy at this point with the quality I'm getting with the FiiO (its tucked behind the stand in the pic).
Just for the fun of it - took the USB output and hooked the Surface Pro into my Audio-gd Compass Headphone Amp....and yes, the Surface audio drivers recognized the DAC right away. And, using my Denon ADH-7000 headphones?
Dazzling!
Subwoofer-depth bass, sweeping, balanced mids and highs...perfect.
Thanks for this thread. I wouldn't have tried it otherwise.
