Wireless Connection - Logitech Wireless Headset
RCGoodin
I'm trying to get the surface to recognize the device and it's not seeing it.
Any help/suggestions will be greatly appreciated.
Come on. I saw where 56 people viewed my request and no-one answered. You can do better than that. This Forum will not be successful if nobody gets involved....
The problem causing no one's answering: since not everyone got his surface and a even smaller percentage uses a bt-device on it, the possibility to have your device and test this successfully is rather tiny.
Additionaly your request didn't included any information on the exact logitech-model or what you have tried so far.
But back to trying to help you:
- Got anything paired with your surface so far?
- Headset is working with other devices/you know how to pair this?
- If Bluetooth: Does the surface support the bt-protocolls the headset is using?
- Sometimes moving the objects (at least 1m space between) could help for recognizing.
- If not Bluetooth: Logitech wireless devices often use the unify-usb-transmitter, using some "proprietary" protocoll - got that working?
Sheesh, seriously? Out of 56 whole entire views you expect your specific issue to be resolved and because it isn't you berate the forum? I think actually impatience from users who demand instant solutions to problems is a bigger problem with forums than anything. Mr. NK has some good points about not everybody even having a Surface yet and you not providing any information to go on. How about instead of complaining about a lack of response you work out the problem and then post your results to share with others who may also encounter the problem and come across this thread looking for a similar solution.
Remember on forums like this you should thank those that help you and you should help others whenever possible. That is what makes a good forum.
JP
