Keep plugged in or run on Battery?
Discussion in 'Microsoft Surface Pro 4' started by larryg-aia, Mar 6, 2016.
  1. larryg-aia
    larryg-aia Member
    Jan 31, 2016
    42
    0
    6
    just wondering if keeping my surfacepro 4 plugged in all the time has any impact on battery life. I do obviously unplug when travelling, but never for too long and then just plug it in again. I know today these batteries don't have memory, but just wondering if there is any suggested way to keep the battery conditioned properly or is it something I don't need to worry about.
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    At least once a month, preferably more, you should run it down to 10%-15% then fully charge it. Try not to keep topping it off as the number of total charge cycles counts against you.
  3. surfacebookinuk
    surfacebookinuk Member
    Nov 17, 2015
    65
    7
    8
    Surface Book
    When you say topping it off what do you mean by that?
    And if I i.e. keep it plugged in how does the cycling thing work?
  4. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Explaining it in a different way don't go to 60% or 80% then plug it back in to go to 100% again. It's not the leaving it plugged in that hurts it's the total number of time you plug it in to top it off, (go to 100%) that hurts. All current generations of batteries have a limited number of charge cycles. If you change it once a day you'll get the expected lifetime from the device, Charging it 3 times a day will cut that back by 2/3.
  5. dcoplien
    dcoplien Member
    Jan 23, 2016
    140
    14
    18
    Wisoconsin
    Actually for this type of battery a cycle = 100% so if you charge every time it's at 50%, two charges=1 cycle, at 25% down takes 4 charges to equal 1 cycle. Time not usage should be used as to when to let it get down to 10% then charge. Unfortunately not all LI-ion batteries are the same. I have a Li-ion battery for a Torqeedo motor where that should only be done once a year, 3 different types for cameras, where each have different run-down times.
  6. surfacebookinuk
    Nov 17, 2015
    65
    7
    8
    Surface Book
    So to get to the original post's question leaving the Surface plugged in all the time when I m home how does that affect the battery?
  7. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Probably not.
  8. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    In theory that's correct, and maybe according to the text books that may be correct but I know a lot of people who followed that theory and now can't operate their devices without it being plugged in and wonder why. The sad thing is that some of those devices are only a couple years old. I only base my opinion on the experience of my customers but that's a lot of experience to draw on.
  9. dcoplien
    dcoplien Member
    Jan 23, 2016
    140
    14
    18
    Wisoconsin
    It will last longer but you should from time to time unplug it and use the battery. Exactly how often is really unknown. I almost always work unplugged. My last windows tablet has been going for three years. I plug it in at night to recharge. That doesn't mean the SP4 battery will last as long but my guess is you should let it run down at least once a month. The app BatteryBar will show you battery wear. You should see more battery wear the first 50~100 hours and then (assuming you use the tablet battery approx. the same every day) it should equalize out. Some Li-ion batteries on their last leg will go quite quickly, others have a slow death.
  10. surfacebookinuk
    Nov 17, 2015
    65
    7
    8
    Surface Book
    So leeshor you are saying that leaving it plugged in throughout the whole time that someone is at his office or home (not away) is the best option for the battery, as long as you cycle it some times per month?
  11. dcoplien
    dcoplien Member
    Jan 23, 2016
    140
    14
    18
    Wisoconsin
    That's more likely due to the build of the battery. Not all Li-ion have the same total cycles. I never trust the cycles quoted by the mfg.
  12. surfacebookinuk
    Nov 17, 2015
    65
    7
    8
    Surface Book
    I so far managed to get 5-6ish hours from my device depending from the way I use it that is.
    But what leaves me frustrated is that the other day I was using it with power saver almost the entire time however it did not prolong my battery in any way!! I don't know how that is even possible. When I was using my Surface Book with the power saver I would get 4 hours more of battery life.
microsoft surface pro 4 how long can i keep it plugged in
should i keep my surface pro 4 plugged in
should i leave surface pro 4 plugged in
surface plugged in battery
surface pro 4 keep it plugged
surface pro 4 plugged in not charging
surface pro keep plugged in
