Security properties problems
Discussion in 'Microsoft Surface Pro 3' started by abdullah., Sep 9, 2016.
  1. abdullah.
    abdullah. New Member
    Sep 9, 2016
    0
    hello
    i have change the security properties of the only drive "C" and checked "deny" for all , and now i cant nearly do any thing , i have tried to do reset and recovery but they all had failed
  2. GreyFox7
    Jul 27, 2014
    6,789
    1,355
    113
    I assume you tried to undo the security settings and tried to take ownership signed in as an Administrator which failed?
    Did you try recovery from bootable USB recovery drive?
    If that failed... boot the Recovery USB again then go to Advanced - command prompt and whack the partitions with diskpart.
    You should be able to use this procedure regardless of 8.1 or 10.
    Using a Windows 8.1 USB recovery drive with Windows 10
