Surface pro 2 replacement
Discussion in 'Microsoft Surface Help' started by Dahnark, Feb 25, 2014.
  1. Dahnark
    Dahnark Member
    Oct 26, 2013
    45
    8
    8
    I am going to do a replacement but the support says me that the replacement device is not a new surface it is refurbished (sleep problems, pen edge sensibility, backlight, etc).
    Is it normal? Google always change the devices for a new devices (I had the typical display issue matches with yellow tue in my nexus 5).
    Really I am not happy with this political point. I think that in Spain (I think Europe too), the device must be a new....
  2. tarrant64
    tarrant64 Member
    Mar 19, 2013
    135
    13
    18
    Nothing political about it. Not everyone replaces the unit with a brand new device. Yes it will be refurbished but that doesn't mean the hardware is junk. If you get a new device and you find something wrong with it- simply return it. I had to do this myself on my last exchange, but the replacement unit ultimately ended up being flawless in the end.
    You're only other option is if you purchased it at the Best Buy and went with their geek squad warranty - in which case they do replace it with brand new.
  3. Dahnark
    Dahnark Member
    Oct 26, 2013
    45
    8
    8
    In Spain there aren't best buy stores
  4. tarrant64
    tarrant64 Member
    Mar 19, 2013
    135
    13
    18
    Was just trying to make a comparison about the warranty options available, but since you've already purchased complete you're really stuck with what they offer. Frankly, there's nothing wrong with refurbished.
  5. Dahnark
    Dahnark Member
    Oct 26, 2013
    45
    8
    8
    I have been reading and in Spain is ilegal change for a refurbished if the device has 1 year or less. Just I do a reclamation... Probably now I get a refurbished and when the reclamation finish in five months I get a new.
  6. tarrant64
    tarrant64 Member
    Mar 19, 2013
    135
    13
    18
    I'm not from Spain so I won't pretend to understand that, but you will want to make sure that the law does in fact apply to you here. Sometimes there's fine print that says if there's an exception or not.
  7. jimkraz
    jimkraz Member
    Jun 21, 2013
    63
    5
    8
    If Spain comes under European rules like UK, it is not illegal after six weeks to replace with second hand refurbished goods though they must be fit for purpose and come with the same length of warranty as your original item had, if within six weeks it will be deemed to have had a inherent fault and you can claim a replacement or your money back, as far I believe.
are surface pro replacements refurbs
sureface pro 2 replacement microsoft
surface 2 pro replacement
surface 2 replacement
surface pro 2 microsoft complete forums
surface pro 2 refurb replacement unit
surface pro 2 repair
surface pro 2 replacement chassis
surface pro 2 replacement microsoft
surface pro warranty replacement pro2
