Another dual Monitor Question
puma
Very simply.. is there a way to hook up two monitors where they will be powered via the video card? I don't want to use a USB connection because I don't like how washed out and crappy the display looks when done this way.
Is this even possible without getting monitors that support something specific like chaining?
Thanks for the reply. Ok I was hoping that there was another way, kind of disappointed there aren't just two ports on the dock.
powered?
From what i have read, it you have 2 displayport 1.2 monitors with DP in AND out, you can daisy chain the video and it'll work. I have also read some hit and miss about DisplayPort hubs.
http://www.surfaceforums.net/forum/...aisy-chaining-monitors-displayport-1-2-a.html
To clarify, as stated in that other thread, only one monitor needs to be DP 1.2-compliant and have the DP output port--and that's the monitor that's directly connected to the Surface. The very last monitor in a DP chain can be DP 1.1-compliant monitor with no DP output ports.
Prior to the SP2, DP daisy-chaining was not possible on the SP1. As a result, I went with the USB approach. As much I was worried about lag and performance before I jumped in, after all was said and done, that setup worked beautifully and I have no complaints whatsoever!
I experienced no performance or lag issues--all while sharing the USB 3 port with Gigabit internet connection and other USB 3 devices. I would definitely recommend this approach to anyone looking for an inexpensive multi-monitor solution.
hmm this looks interesting. I want to make this my primary computer, but I need the two monitors (without being washed out)... i will let you know if I try this.
